TwinTurbo.NET: Nissan 300ZX forum - Could be a lot of things. What are you using? Does it burn>
Subject Could be a lot of things. What are you using? Does it burn>
Posted by Zealot on August 03, 2000 at 12:25 PM
  This message has been viewed 28 times.
In Reply To What is happening to my motor oil?, my oil level > posted by chriztopher kent on August 03, 2000 at 11:32 AM
Message (blow smoke)? Have you had it checked for leaks? Z's often have a rear main seal leak, which is hard or impossible to detect w/out dropping the transmission. Some other leaks, depending on where they are, may burn off the seepage and you may not be able to tell (give it a sniff :) Barring the obvious, leak-wise, have it dye tested to see what happens. Hope that it's leaking and not burning. For me, switching helped. I always run synthetic (Mobil 1). I switched to 10W-30 and have not lost a thing. Good luck!
